how do i change the time on the hub
how do i change the time on the hub? Version VMB4000r3. firmware 1.25.1.0_4598_1f1c874
It's now in Settings, Home, Time Zone.
cant repost pic see next post
That does not exist on my home screen. See image above.
Do you use Library to view recordings (old interface) or Feed (new interface)? For the former, try this (yes, it says camera but try the base):
https://kb.arlo.com/000062607/How-do-I-set-the-time-zone-for-my-Arlo-camera
I see your screenshot now so you're using Feed. You're in the wrong place. I simply click on Settings, Home and Time Zone is right there.
@dbharness: If you entered an address for the location, then you cannot change the timezone. It's locked to the timezone used at that address.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
