I'm trying to complete the install of my Essentials wireless doorbell. I've found these steps from a Google search...
I've found 'Settings' after clicking the small head & shoulders icon at top left of the home screen, but on the next screen (my account profile and security) there's no obvious trace 'Device Settings' or 'My Device' etc... Am I barking up the wrong tree? My doorbell has got the latest firmware, downloaded today during installation, and the Arlo Secure App on the phone is V 4.11.2_28633, release date 23rd Jan 2024
Do you see "Library" as a menu option in the app? Or do you see "Feed" and "Dashboard" instead?
He has the new UI as evidenced by the "small head & shoulders icon" at the top left.
In there click on Home and then Devices. It's ok to look through the whole interface although that's not really what you need at the moment.
Assuming you're looking at the actual FAQ and not just some text from your search, note the link at the top that points you to the correct FAQ for the user interface (UI) you're using. I'll post the link here:
'Home' --> 'Devices' just takes me to the live view through the camera lens. If I select the head & shoulders icon on the home screen, this takes me to.....
No mention of Devices. However, I select 'Home' and get this:
I select Devices and then 'Arlo Doorbell' and voila! Bit of a scenic route to get there.
Going off-piste a bit, I'm new to Arlo so will probably have further dumb questions. One I can think of immediately is that if I want to include a picture in a post, I can only see it if I hit the Preview button - is this correct? And how can I resize it?
That's not all. Touch one of the cameras and you'll find a settings wheel in the top right.
@StephenB wrote:
@splinternet wrote:'Home' --> 'Devices' just takes me to the live view through the camera lens.
"Cameras" ??
@splinternet wrote:
"Cameras" ??
Home->devices presents a list of the cameras (and doorbell), showing an image of each camera.
When you touch one of the cameras or doorbells in a spot that is not over the play control, then a new screen opens that includes the image, and the feed for that camera/doorbell. It also has a settings wheel in the upper right of the screen. Select that, and you'll see the camera settings.
If you touch another class of device (a hub for example), then you will go directly to the settings for that device.
Alternatively, you can touch the three dots in the upper right of the devices screen. You will then see settings wheels for every device.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
