When will Arlo make serious improvements to the app and camera system? Paying 9.99 is not worth it
What bugs are you experiencing within the mobile app? Could you provide details?
If your cameras are not catching a lot of motion, it could be due to sensitivity or positioning. Keep in my the maximum effective PIR range is around 23 feet. Beyond that, the cameras may detect motion but will likely be inconsistent. For more information on positioning and adjusting sensitivity, take a look here:
If you're seeing image distortion, this is typically a sign of interference or poor signal strength. An easy test is to temporarily relocate the camera and test to see if the issue still occurs in a different location.
You can adjust your camera to record for a fixed duration when motion is detected within the camera rules. You can also adjust motion sensitivity if you're experiencing issues with the camera detecting nearby activity.
Take a look at the steps in these articles for more information:
https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
https://kb.arlo.com/1079027/How-do-I-adjust-Arlo-video-recording-length
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
