I have a VMB4540 R2 hub, and two H9 cameras. The hub and the cameras and my mobile device are all connected to the same Wi-Fi. But when I go to set up HomeKit under the hub option, it does not discover anything. I’m dead in the water and can’t create a HomeKit that my appletv will recognize.
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Worked like a dream. Thanks for the support!
Any idea why the stream stops as displayed through the appletv? I would like to have the stream run full time from my driveway camera in the right corner of the screen. But do some reason it disconnects after a few minutes. I don’t see it doing that though your mobile app or the HomeKit app. Just the image on the tv being fed from the apple tv.
It may be a security feature. Have you had this set up previously and that was a feature that worked?
Yes but didn't use it long enough to notice it back then. You folks sent me a code to refresh the hub - which worked.
I'd like to have the ability to have continued streaming of a camera via my appletv feed to my TV. Just curious if there was something on the arlo side that blocked this? I don't see one.
This article will explain the live streaming and why it stops:
https://www.arlo.com/en_eu/support/faq/000062226/Why-has-the-Arlo-app-stopped-live-streaming
Thank you - I’m good here.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
