Since updating a couple of days ago to the new Arlo app on iOS, Two Factor Authentication using my device won’t work. I’ve tried removing and re-adding my device but that didn’t help. The other method(s) still work so I’m not locked out, but it’s inconvenient and should work.
Message 1 of 3
6,564
Hi. It was the authenticator in the app that wasn’t working; the other method(s) worked. I use the past tense as this now seems to have resolved itself; not sure if it was just a glitch or if the removing and re-adding helped at all. Thanks for responding so quickly.
Message 3 of 3
6,552
Are you saying that you need to use a different method on the phone? Or that you need to use a different method with other devices (like browsers)?
FWIW, I am running the 3.6 app on my iPhone 12 mini (iOS 15.3.1). Web push authentication from my PC browser is working as it did before.
Message 2 of 3
6,557
Message 3 of 3
6,552
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
