Want to continue to record but do not need notification At Home. How can i turn this off? I disabled notification but i keep getting them!
Did you disable the notification in the rule for the camera in the mode(s) you are using?
Yes I have disabled notification in the app but i noticed that it was still enabled on in the web portal. I disabled but it got enabled again. Disabled one more time.
STILL got notification!
Please go through this article and make sure that you have followed all the steps fully.
https://kb.arlo.com/000062908/How-to-Mute-Arlo-Notifications-Arlo-Secure-4-0
If you do still see the same behavior after looking over the article please reach back out.
I wanted to mute 1 camera not the app.
After about an hr or so, the notifications have reduced and is only recording HOWEVER i am still getting people notification. Thanks
Hello I've the same problem
Have been using two old arloQ cams, and recently my app is upgraded by itself as Feed style.
And now I've so many notifications when the cams sense Motion Detection > under the Rule with Record video On & Send Notif to everyone OFF.
So, the "Notify Everyone" option is absolutely no meaning.
I want to use Recording feature when arloQ senses Motion, but dont want to have any notification.
Before this app upgrade, everything was fine.
Thanks.and hope to be corrected soon.
Can you try removing the camera from the account and re-onboarding it?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
