We have a Smart plan and want to change the plan. The change plan button is greyed out and can't do anything. Arlo are still happy to take my money though. Anyone else having this issue?
Might make sense to contact support on this (using the support options in the app).
You could try cancelling the Smart plan, and then see if you can subscribe to secure. But if it stays greyed out, you'd end up with no plan.
tmg2714,
Could you provide a screenshot of what you're seeing?
@BellEnt wrote:
I have same issue. Change Plan button grayed out. When I click resume subscription just shows null in orange at top.
Did you try canceling the existing plan, and then re-subscribing?
BellEnt,
I will review your support ticket and request a status update.
Yes. I don't have any new information at this time. The escalation is still pending.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
