New app version notification issues
Has anyone noticed that with the new app version while using the Home Secure system, the notifications are not seen unless you have the app open . Like if the system is armed home, you wont get any notification form any of your cameras at all. This makes no sense
I'm getting notifications on Android with the app just backgrounded. You're not logging out, are you?
Yes i am logged in. Thats why i am deeply concerned. This is not a cheap system. Yet falls short . I had some tech support helping but the problem still persists
Oz2009,
Are you getting recordings? Check your app permissions to make sure notifications are allowed/enabled. If you're still experiencing an issue, try uninstalling and reinstalling the app.
Yes i did all those. I had the tech support for an hour trying to figure out what was wrong. At the end he said that because i have another user for the system on my app thats why the notifications weren't sent, which makes no sense, once i removed the user then the notifications started flowing in.
but my family can't use the app then ??!!!
I stopped getting Push Notifications on Monday 26th, prior to that, all was working fine since purchasing Pro 4 system in November 2022, no settings where modified in IOS or Arlo App, it just stopped ...
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
