Hello my base station light is solid red and I have tried to replace cables and nothing seems to help.
Have you tried a different LAN port on your router?
Thank you. I did try that too. Changed all cables, ports on the router, charge port. Etc no luck
Do you see the base station in your router's attached device list?
Yes I see it in the list.
Ok. The color is actually amber (though often it looks red) and means "An error has occurred or something is wrong with the connection."
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
Since the base is in the router's list, the problem is not the ethernet connection to the base. It could be that the router is blocking the connection to the Arlo Cloud, or it might be some other error.
Does the base still show up in your Arlo account?
What model is it? (There is a VMBxxxx label on the base).
I would also suggest power cycling both the router and base, in that order.
The model number is VMB4540 and I don’t see it in my router list anymore.
It does show in the router list now that I have power cycled it.
Yeah I did not it turns blue solid and then goes red
Had to buy a new base station as this one went bust! I must say the build quality is very bad.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
