Immediately following the Secure App update to 6.3.8, I’ve had a strange false problem occur on 3 different cameras now.
Get a message that a camera is not able to recharge its battery.
But the battery icon shows it's full.
And when I click / look at the camera device info, it shows it’s 100% fully charged.
Never had this problem before on any camera over the years. Now it's happened on 3 different cameras since the 6.3.8 app update.
Hi all, just wanted to let you know this should now be resolved. An update was performed on the backend. There should be no further action needed on your part. The deployment is in a slow rollout phase and should be completed by end of next week. Please let me know if you're still experiencing these symptoms after that timeline.
Happens to me as well, but I see it alot more when I use a long USB cable like 20+ feet. Not sure if its impedance but its consistent, but does charge. When I use the long cable with the Pro and Pro2's, no red icons or errors. Just the Pro4 and Pro5s.
With the recent app updates, Now I get that red icon and error even when using an official Arlo USB brick and official short cable. Both in App and Web browser, so I dont think its app related. The backend probably thinks you're connected to a solar charger.
Arlo doesnt even send a official brick anymore, but throws an error now for everything; 1A or 2A doesnt matter.
Typical Arlo problems?
FWIW, Arlo's outdoor charger for the Ultra/Pro 3/Pro 4/Pro 5 (25' cable integrated with the charger) delivers 9 volts instead of the usual 5. That reduces the power loss in the cable.
FWIW, over the years I've used sets of Pro2, Pro3, Pro4, and then Pro5s Cams...always had good power to them.
Never once in all those years with all those different Cams in the same spots with the same power did I ever have the false messages I immediately started getting on multiple Cams when the secure app pushed out version 6.3.8.
I see they've now pushed out version 6.4.0...watching to see if that has a fix.
Didn't realize that was a thing. good to know. I just assumed the same would work on the pro4/5 due to always using 20+ foot cables with the pro1-2's just fine.
UPDATE:
My false messages about cams being unable to charge suddenly started happening when secure app version 6.3.8 came out.
Likewise, the false messages have suddenly stopped when version 6.3.8 was replaced with version 6.4.0. Haven't had another one since...
Spoke too soon...version 6.4.0 didn't fix the false message problem after all.
Just had another false message about a cam that always has a 100% charge on it, and is on a short 6' cable with the high power charger unit.
UPDATE...........................Latest Secure App Version 6.4.2 just released
Appears to be a positive update...Faster, couple flaky issues seem to be gone.
Will know more after a couple days...but it's initial impact seems good.
FWIW - Noticing a new strange issue with latest secure app version 6.4.2.
When click opening the App on my iPhone, all the camera screens are black with a red exclamation mark in the middle of the screens.
Then after waiting a minute, all the camera normal screens begin appearing one after another.
FWIW, I've been seeing that for a while (well before 6.4.2). In my case, it starts filling in the screens in just a couple of seconds.
...more of a figure of speech than a lot of specifics.
My experiences have been a few seconds to literally a half a minute, depending on how many of them appear with the off / black screen / exclamation point showing.
If I hear something and grab my phone to take a quick look, I expect my cameras to be on.
Instead, this latest new set of problems interfere with that.
I just SMH at the never ending problems...
Does it occur on wifi and mobile data? I'm not able to replicate this as you described.
Mine happens on both.
And the latest version 6.4.4 that just came out didn’t fix the weird messages.
Screen shot attached:
iOS right? Do you mind sending a log for the team to review?
I let the team know as well, just waiting for more info regarding this. I will add it here when received.
In recent Arlo Secure app updates, my Arlo cameras and Base station keep going in offline when I open the app. However, this is only temporary and I need to wait anywhere from a few seconds to about 15 seconds and then it comes back on line again. All is good for a while but then when I try to open it again about half hour later, it starts all over again. I have a 500mbps internet connection, I have rebooted my wifi router, and restarted my base station several times but none of this helps. It’s very annoying when I want to check movement on my cameras and then have to wait up to about 15 seconds for it to come on line again - which defeats the purpose of wanting to check a camera movement immediately. Does anyone have the same problem or any suggested solution? Or could it be the App that has bugs that cause this recent behaviour? It happens on both my iPad and iPhone both running ios26.
Hi @RTB-oz
Is this represented as a black thumbnail with red exclamation point or an offline message? Do you happen to have a screenshot as well?
Yes, black thumbnails with red exclamation points inside a red circle. (I will try to upload a screen shot but the Upload button doesnt seem to be working.)
Yes, happening to anyone, not just you.
And its nothing to do with any of your personal home network or iphone / ipad equipment or software.
It's clearly another new arlo problem that started recently...been talking about it in the thread about the Secure App versions for weeks
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Thank you. I’m glad it’s not just me then. But it just reinforces my dread of app update releases yet again introducing new bugs. This has happened to me several times now for app updates to introduce a significant new bug in an app that was previously working well. It seems the development team do insufficient testing before releasing a new update for this to be such a regular feature.
Every single time I open my app for the last month or so, all my cameras are immediately offline, but just like yours, they’re not. I have click on one of the cameras, see the videos and maybe even click on one of them AND THEN the cameras will show online. It’s infuriating because it’s impossible to see what is going on in a timely manner. I’m so angry with these stupid changes they’ve made. Everything is absolutely worse.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
