  • 34 Replies
  • 17820 Views
  • 71 Likes
  • 16 In Conversation
Azurespire
Is there a way to revert this dumb update? I updated the app on my iPhone 13, and it singlehandedly RUINED my set up.  I had 3 cameras and a doorbell. once I updated to the "new" app not only did they all disappear they will not come back. I tried revoking access and inviting myself back in with no success. i have other devices on older versions of the app and they work just fine. this is ridiculous. is there a way to revert the app update and go to the older version of Arlo secure: home security app or am I just screwed from this device. I have re-sent invitation emails to my other devices and they have access but they do not pop up in the app.
34 REPLIES 34
You just identified the issue. All users have to be on the same UI to have guest accounts working. Since one is using the new UI, you need to migrate all the others, too.
Azurespire,
There are two interfaces within the Arlo mobile app today. New accounts will see a new UI experience, this shows a "Feeds" tab across the bottom of the app. Accounts that were set up previously will show a library tab across the bottom of the app. Compare the app interface on your accounts. Both accounts will need to have the same UI experience showing "Feeds".
If your account does not show "Feeds", you will need upgrade your account UI by attempting to onboard a security system or a Pro 5 camera (even if you do not have one). Once you enter the onboarding flow for one of these products, you will be prompted to update the app to the new UI experience. After completing the upgrade, you can then leave the onboarding flow and share devices.
Please let us know if this works.
KajRN
We are experiencing a similar issue, my husband owns the account with the version 4.0.4 (5464) when I logged into my shared acct this weekend my app forced me to upgrade to 4.9.1 (6960)  I lost all access to 3 cameras.  We have tried deleting my app, resharing under. Different email etc… no access.    From what I understand in order for me to see anything he also needs to update his app?
and what is an UI?
any help is much appreciated
For starters, his app is VERY old and he should update. Your app doesn't cause you to lose access but if you have migrated to the new user interface (UI) that uses Feed to view recordings as noted above, your husband ALSO needs to migrate which will require the latest app.
4nancy
I couldn’t be any more Pissed about this. What a mess!! I have 6 non working cameras and since I don’t pay you for cloud service, I’m not allowed to speak to customer service?
I’m talking to Costco about getting rid of Arlos at this point.
The system wasn’t broken, it was great. End of life is what will happen to your company if you don’t fix this and stop blaming US!
4nancy
This is all mumble jumble to most people. Just answer your phones and help us.
i wi he starting a class action lawsuit if you don’t. There’s plenty of documented cases of loss on line to support it. You can’t sell someone a product that stops working because you upgrade the app. We’re out over $2k because you refuse to provide customer service to address the problem.
markoz
I can't believe Arlo have done it again.  A year after their major stuff up with the whole EOL fiasco, they've now created another shambles with the feed vs library interface debacle.  I previously had custom modes defined so that cameras behaved differently based on a timed schedule (e.g the camera in my garage would be alarmed during the night).
I was forced to switch to the new feed mode due to problems sharing cameras with my wife and now all my schedule config has been lost in the switch.  I've now got to try to work out how to set this all up again (or work out whether it's even possible now) with the new feed interface.
It was all intuitive with the previous interface and it sounds like they over-complicated it all.
I'm seriously considering switching to another camera brand as Arlo continuously creates headaches for their customers.
markoz
OK, so having done further research on how to use the Arlo app now (I had to dig around on various forums, as the Arlo documentation and Youtube videos are hopeless) , my understanding is that we are now restricted to just three modes.  i.e. the functionality to add additional customised modes has been removed.  My requirement is to have five modes which is no longer supported.
What a joke!
After the EOL fiasco for older cameras last year, I was happy that Arlo revoked the decision and even offered newer cameras and subscriptions at a reduced price.  I thought that maybe they've started treating their customers better and even bought new Arlo cameras at the discounted price.  Now less than 12 months later, I discover that these cameras no longer provide the required functionality.
If anyone at Arlo support actually reads these forums, please could you correct me if I'm wrong with my understanding that it is not possible to add additional modes.
I purchased my latest cameras on the expectation that customised modes were supported (which seemed like a reasonable assumption as this has been the case since I first starting using Arlo cameras in 2016).
As this functionality has now been removed, the cameras no longer meet the Australian ACCC consumer right's guarantee that a product must be fit for purpose.  As such, I will be requesting a full refund
While Arlo continue to treat their customers with a complete lack of respect, I would not recommend that anyone purchases Arlo's products.
Retired_Member
Not applicable
NEED HELP!!!!! - Arlo’s new app undate, prevents viewing of Video recordings on base stations.
You can't see them in Feed.  Go into "Devices", press the base station, and then go into "Storage Settings".  You'll see them there.
Retired_Member
Not applicable
I tried that over and over again, and still nothing!!
What base station model do you have?  (Look for a VMBxxxx label on it).
Also, what model cameras do you have connected to the base?  Do you have a subscription?
Retired_Member
Not applicable
Are there any class action lawsuits, pertaining to the Arlo update that prevents you from viewing Base station camera recordings?
Tanja88
Good luck!  We are about to throw our whole system in the trash.  New app is so bad!  Who thought this was ok?  You cant even turn cameras off and on anymore.
I can view mine.  If you have a VMB4540 or VMB5000 with direct access to local storage enabled, then with Feed you
  • navigate to the devices page
  • select the base
  • select storage settings
You'll find the recording there.
I asked you about your hub model, since a lot of people with VMB4000 and VMB4500 bases mistakenly think the recordings they see are locally stored - when in fact they are in the cloud.
You can - see my reply to my other thread.
It is quite different, so it is useful to do some exploring.  Several features work differently, or have been moved.
The difficult spots are
  • there are no custom modes (hopefully Arlo will add them)
  • the combination of geofencing+scheduling doesn't completely work.
  • there are some issues being reported here with Arlo Go cameras.
Radses
I think someone missed the point
The new UI interfaces terrible and I do agree that there needs to be a way to revert back to the older version because it was much more easier to control much more easier to set up and easier to share the platform with friends or family this new system you've overthought it it's too complicated and very long winded just a complete waste of time so again so how do you actually revert back to the older version of the UI?
You can't.  And even if you could, it would only be temporary.  Arlo won't keep the old UI working forever.
Note I don't work for Arlo.
Aussie54
Sadly I believe customer concerns relating to software upgrades on multiple occasions are simply ignored.
Like it or not, this recent "upgrade" is an unmitigated disaster and to date I have not read one positive post. It's quoted that it isn't possible to rollback to the previous software version so my only option is to scrap my 12 cameras and 2 base stations as they are no longer fit for purpose. I'll vote with my feet be actively reviewing alternative systems. Arlo hardware was once a premium product but has been trashed by software engineers that mistakenly think they know what the customer needs.
I assume EBAY will be  soon flooded with unusable Arlo systems.
I'm done , I'm out!
ThisnewArloSukz
How does one set one camera to be armed all times, and three other cameras at separate night armed, say 8pm to 8 am? I can't find a solution.
@ThisnewArloSukz - I replied to your other post. Please don't post duplicates.
londonmr66
I have the same issue since the app updated on my phone. I can see the videos in my local library but when I try to playback a video the app shutdown. As expected Arlo won't talk to me because I don't have a subscription. The app on my tablet has not updated and I can playback the videos with no issues. I also cannot rollback the update on my phone. Arlo need to fix this
What version is the app as well as the phone's OS?  I'm using the Android app 5.4.0 on 2 different Android OSes (13 and 15) with no problems.
londonmr66
The app is 5.4.0_28783 and my android is 13. I don't havethe issue on my tablet so it's not the hub or my network that is the issue. I can watch the live feed from the camera, its just the video playback that crashes the app. Any help would be greatly appreciated
