Hi,
im having issues with my home address on the app. My home address when entered shows my neighbours property which is around 1/4mile away. Not ideal for using the Geofening.
I’ve tried and tried all sorts of addresses combinations but with no success .
Any help would be greatly appreciate.
Martin
are you referring to Routines >> automations >> Arrive/Leave ? If click one of the geofencing automations there, you can "Edit Geofence", then drag the map to change the address to wherever you want (and optionally set the geofencing radius), then SAVE.
Hope this helps.
Alex
Hope this helps.
Alex
Hi,
if I go into settings and check my home address it shows my neighbours house which is no where near my house.
I can enter different address combinations for my home but the home icon still remains at my neighbours house.
But did you try the dragging suggestion above?
Hi,
yes this has worked.
Thanks 👍🏻
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
