I currently have the old Arlo experience and have tied together geofencing and scheduling so I can use three modes as follows:
Away - everything armed
Home, Day - Two specific outdoor cameras armed, notifications on one of them
Home, Night - All outdoor cameras armed with notifications.
Whenever I’m at home it automatically cycles between the two Home modes; if I’m away it goes in to Away; when I come back, it always goes in to the appropriate Home mode for that time of day.
I’m led to understand that the new app experience is very limited in its customisations and automation. Would I be able to recreate the above?
Thanks in advance.
Ah, as luck would have it I came across the answer right after leaving this post:
https://community.arlo.com/t5/Arlo/Combine-Schedule-and-Arrive-Leave-Automations/m-p/2340467
The answer is “no” and it also seems that the automation features have been almost completely removed from the new app and replaced by a couple of crude rules that can trigger specific actions. I cannot fathom how a company that designs security systems could come up with that design, what a fundamentally unserious business Arlo is.
I had no problems with scheduling on the old software; however, the new software does not do what the instructions tell you to do and on top of that you cannot get help from arlo unless you are a paying customer. Unbelievable!!!!!
Did you read the FAQ posted above?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
