Invalid Home Address
  • 4 Replies
  • 2055 Views
Martin0711
Hi,
im having issues with my home address on the app.  My home address when entered shows my neighbours property which is around 1/4mile away.  Not ideal for using the Geofening.
I’ve tried and tried all sorts of addresses combinations but with  no success .
Any help would be greatly appreciate.
Martin
alex_loo
Virtuoso
Virtuoso
are you referring to Routines >> automations >> Arrive/Leave ? If click one of the geofencing automations there, you can "Edit Geofence", then drag the map to change the address to wherever you want (and optionally set the geofencing radius), then SAVE.
Hope this helps.
Alex
alex_loo
Virtuoso
Virtuoso
Hope this helps.
Alex
Martin0711
Hi,
if I go into settings and check my home address it shows my neighbours house which is no where near my house.
I can enter different address combinations for my home but the home icon still remains at my neighbours house.
But did you try the dragging suggestion above?
Martin0711
Hi,
yes this has worked.
Thanks 👍🏻
