How to add camera to existing multi camera sub
  • 4 Replies
  • 2588 Views
FirstCup
I have an arlo secure multi-camera subscription. It has 5 cameras on it now, 3 pro 3 and 2 pro 2 cameras. I purchased a 3 pack pro 4 cameras and wanted to add two of them to this subscription which I understand is allowed unlimited cameras on it. I synced the camera to the VMB4540 with no problems but it only showed up not as a sixth camera but a new one requiring a subscription as a 30 trial.
How do I get these cameras to show up as a participating camera 6, 7 & 8 if I chose to do it that way?
The cameras are automatically opted into the trial when installed.
You can cancel the trial, and then you should be able to addd them to your existing subscription.
FirstCup
I did not see anywhere that I had an option to cancel the trial subscription. At the moment I will not need this information as I needed to return the cameras over quality issues. I may try a replacement set of cameras in the future but not sure, I need to get my refund first. But I will look for that option if I try again.
It is definitely there - the same steps that you use to cancel any Arlo subscription.
FirstCup
Thanks for the help! I did go ahead and reorder one pro 4 camera and I'll see how that works for me.
