  • 30 Replies
  • 22174 Views
  • 3 Likes
  • 12 In Conversation
AntBW
Does Home Secure with professional monitoring allow/meet the needs of insurance companies (and therefore allow you to qualify for the insurance discounts)?
Best answers
  • ShayneS
    Hello,
    The following conditions must be met to access the certificate.
    • Customer must have Arlo Home Security System onboarded at location
    • Must have a monitoring entitled plan at that location (eg. Safe and Secure Pro plan). Free trial is not applicable, needs to be a paid plan
    • Must have ER setup done
    Steps to access certificate
    1. Login to https://my.arlo.com/#/home Web client (not supported in mobile clients)
    2. Click on the top left home icon area to display dropdown options
    3. Click on “My Arlo Account”
    4. Click on “Download” to download certificate in pdf format (look for Monitoring Certificate section under the eligible location (s) with plan)
    Note: that Arlo is neither responsible nor guarantees any discount, that is purely between the customer and their provider.
30 REPLIES 30
ShayneS
Thanks for the update.
BartHammond
I can locate my Monitoring Certificate ... however, when I view mine it is checked for:  Freeze, Video Verification, Burglary/Trespass ... and NOT for Smoke Alarm Detection, Carbon Monoxide Alarm Detection which my insurance company requires.
I do have separate Smoke Alarms and Cardon Dioxide Alarms.  How do I get my monitoring certificate to check those circles/boxes?
ShayneS
Hi @BartHammond Great question, To enable the Smoke/Co feature please use your app to navigate to Devices > Select the Security Hub > Settings Cog in the top right > Select Smoke/Co Alarm > Enable Detection > Follow the prompts and make sure to save any progress if asked. try logging out and back in via the  web portal and review the certificate again. Hope that helps.
BartHammond
Perfect, it worked.  Thanks for the help
J10B
I’m having the same issue. I have the 24/7 monitoring and setup the Er and nothing no cert
ShayneS
@J10B
The certificate is available when a Home security system is installed and subscribed to the Safe and Secure Pro plan.
