Feed
I have the same problem. Under Feed there is this notification below, and there is nothing I can do to change it. Arlo does not have technical support either.
"You found a premium feature.
Visit Arlo on the web to manage plans and devices"
A premium feature means you need a subscription to use it. Technical support also requires a sub. You can purchase a single camera monthly plan to contact support and then cancel it afterwards if you wish. Note that without that sub there are no cloud recordings once the trial expires.
I’m getting the same message on mine and have had a subscription for at least a year if not longer. So I then upgraded my subscription and I’m still getting the message. When I try to go to the camera and watch it live is when it happens. NEVER HAD THAT BEFORE.
I'm having this issue too - also have an established subscription - message and behavior appear to be a bug with the app. Contacting support seems difficult. Frustrated.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
