Can't Install security light
  • 18 Replies
  • 6607 Views
  • 8 In Conversation
Ashley2018
I have the old legacy cameras that work just fine still. I went to remove one of them and then when I went to add more devices, I click “add camera” and nothing happens. It’s not clickable. I can click “lights” underneath it though. But for example if I was to go ahead and click “security light” it’s also unclickable. Seems like the app is messed up. I have a subscription and confirmed with support that I can have up to 5 legacy cameras. Tried to log into arlo through the browser but it just lags on the trust this device screen. What gives!?
18 REPLIES 18
Have you tried doing this from both your phone and a PC?
Also, have you tried a different PC browser?
If you have Arlo Secure, then you can have unlimited cameras (any mix) in a location.
The "up to 5" is the limit for free cloud storage (and applies if you don't have a subscription).
Jackkwan14
I have the  same problem
Dbensette
Luminary
Luminary
Same issue, iOS app is unresponsive when trying to “add camera”. Adding a light, doorbell or base station all work. Option for adding a camera is broken.
FWIW, I am not seeing that on my own iPhone.
Do you see "Feed" and "Dashboard" in the app menu?  Or do you see "Library" instead?
Also, what version of the app are you running?
Ashley2018
Using version 4.9
I only see library. My profile just says “gathering information” and never does anything. Somethings definitely wrong with the app, and it doesn’t appear Arlo is addressing the issue.
ShayneS
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Can you provide a list of the devices that cannot be added.
Ashley2018
Hello,
I’ve removed the app from my iPhone. I’ve added and deleted it with airplane mode/wifi.
i installed the app to the latest version. My iPhone IOS is also the  latest version. Although I’ve installed the latest Arlo app, it shows library not feed. My profile says “gathering information”. When I go to click add new device, you’re unable to click from the list of features such as “add cameras, add lights, add doorbells & chimes, base station hubs”.
I’ve tried to log in from google chrome, when I click trust this browser, it will circle and nothing ever loads. It appears the app is glitched. Although, it says it’s the latest 4.9 Arlo app, it is not showing or doing any of the things demonstrated in the photos on the App Store. People are going to buy camera and not be able to install them because when you click add cameras it doesn’t do anything.
Dbensette
Luminary
Luminary
I deleted the app, did a hard boot on my phone, installed the app again and it’s still acting the same. Can’t add a camera, only working option is to add lights, doorbell or base station. Anywhere I click on the screen where it shows the option for adding a camera it is unresponsive.
Dbensette
Luminary
Luminary
It’s an iPhone 15 pro max, app version 4.19 (8201)
Dbensette
Luminary
Luminary
Also on the setting menu under “account”, it keeps saying “getting information” just like the other user seems to be experiencing. Obviously not an isolated case.
ShayneS
Is it possible to provide a screenshot of the "gathering information" messaging?
Dbensette
Luminary
Luminary
ShayneS
@Dbensette
Thanks for the SS.
Bos15
Does anyone know what to do ? On devices, add a new device, the camera button is frozen . Cannot add a camera. The others buttons are not frozen , just the camera.
DannyBearAgain
A workaround is to add the camera manually. Momentarily press the base sync button then the camera sync button.
Ashley2018
It’s working now, however my app still not has updated even though I have the most up to date version of the Arlo app. Once logged in, it has not updated to the new look.
Jugge
I can't connect my bridge to wifi. I have tried two different wifi, at home and in the summer cottage. Have restored several times but with the same result. It finds bridge but then it stops at wifi. Can't connect?
Jugge
End yes. It is 2,4 ghz network
