Hello, probably a simple question but couldn't find it online:
Does the Arlo Secure plan (e.g. 9.99EUR/mth plan in NL) include multiple Ultra 2 cameras as well as the Arlo Video Doorbell (wired)? Or do you need 2 secure plans (1 for the cameras, 1 for the doorbell).
Thanks in advance!
https://www.arlo.com/nl_nl/serviceplans
The €9.99 plan has unlimited cameras (and includes the doorbell).
But if you want 4K video from the Ultras, then you'll need to get Secure Plus ( € 14.99).
Thank you Stephen. And just to confirm / clarify:
1. For the Ultra 2 cameras: with the €9.99 Secure plan you can watch up to 2K in the app (cloud recordings), but local recordings (USB or SD card in the base / smart hub) are saved in 4K (also when you have a Secure €9.99 plan), correct? Or is the maximum local recording also set at 2K if you have the €9.99 Secure plan?
thanks!
Maximum local recording is also set at 2K.
Are you sure? When I purchased the system I read something else..
Is 4K recording free?
Yes. All users of Arlo Ultra can stream 4K content without a subscription. You can use 4K by local live streaming or recording 4K motion content onto a microSD card when inserted into an Arlo SmartHub. You can also purchase an add on service to store 4K, motion-activated clips to the Arlo Cloud for easy access anywhere your mobile app has a data connection.
@hugggg wrote:
Are you sure?
Yes.
- If you have no subscription, then you can get 4K livestreaming and 4K local recording for free.
- If you have a 2K subscription, then your local recording is locked to 2K.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
