I have 7x Arlo pro vmc4030 cameras 2 stopped working on my Base vmb4000 a few weeks ago so I have got a second base vmb4000 and I am trying to sync them to it and they aren’t working. Is that because they are now EoL? One blinks blue when plugged into the charger and the other blinks amber once or twice also only when plugged into the power I cannot get them to sync to my base I have reset everything
No.
Is there a reason you thought getting a second base would fix the original problem with the cameras?
I already had a second base
Are you syncing with "add device" in the app?
Or are you syncing using the buttons on the base and camera?
Did both cameras stop working at the same time?
I have tried both and nothing.
Yes, both camera stopped working at the same time
Are you still seeing this same behavior?
Yes both cameras still will not sync I get one amber and to blue flashes when I plug into power and nothing anyone time
add TAX number
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
billing
cameras
custom modes
Friend
Grant Access
My Arlo
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
