I am looking for the same set up I had but with this new app and I can't for the life of me figure out how to do it. This new update is not intuitive at all
Ok so I want to set up Geofencing while both phones are away and a schedule to arm all cameras from 7pm-7am.
Is this possible with the new update? Can anyone walk me through it?
And what do you want to happen when you are home between 7 am and 7 pm?
2 cameras to be activated for any motion and notify me
Ok.
This discussion should help:
That schedule is similar to what you want.
Ok I have automations set what ones should be selected under each mode?
Right now I have every automation selected in arm away, arm home and standby
Use the settings in my screenshots in the linked post.
Schedule automations: Arm Home, Standby
Do you also use Geofencing?
Yes, I have geofencing and schedule set up. Do I leave all the geofencing and schedule automations on for all 3 modes? What I am talking about is the automation toggle option when you go to the mode settings. This option to select/deselect automations is quite confusing. I tried to post a screenshot of what Im talking about but am unable to
I get this is confusing. Note the settings you are seeing in the mode are also shown in the automation config - just presented differently.
Again, the schedule automations should be enabled in Arm Home, Standby - but NOT Arm Away. If you were to enable them in Arm Away, then the schedule would continue to run when you are away from home. Which you don't want.
Your "Arrive" automation should only run in Arm Away (and NOT Arm Home or Standby), since its purpose is to take the system out of Arm Away.
"Leave" can be left enabled in all modes (though Arm Home, Standby is enough).
Ok just to summarize and make it concise and hopefully help out other people. Does this look correct?
Arm Away:
Schedule Daytime: Off
Schedule Nightime: Off
Geofence Arrive On
Geofence Leave: On
Arm Home:
Schedule Daytime: On
Schedule Nightime: On
Geofence Arrive: Off
Geofence Leave: On
Standby:
Geofence Leave: On
Yes.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
