Arlo Subscription
  • 2 Replies
  • 1857 Views
Retired_Member
Not applicable
I am trying to start a subscription, but during checkout the country is defaulted to Switzerland and I can not change it to United States.  Is there a solution for this?
Where did you initially create your account and set up the system? You may need to remove all devices from your account and create a new account to set the system back up to get the correct country set.
Retired_Member
Not applicable
I might have setup up on my phone. I was using a combo of phone and desktop and can’t remember which one exactly I used to create the account. I will try the delete and recreate method suggested and see how it goes. Thanks!
