Arlo Secure Not Recording To Library
Can someone please help. I have an Arlo Pro 3 Floodlight Cam and when it was on the free trial it worked perfectly - every movement was captured by the camera and uploaded to the library.
Since moving to the paid for Arlo Secure plan it has been completely and utterly useless. I'm really frustrated. I've contacted tech support but they've just blamed my wi-fi (although nothing has changed since it worked perfectly with the free trial). I've performed factory resets, and deleted and reinstalled the app. I've tried everything and it's still completely useless. Although the camera is mounted by our front door some days it doesn't capture a single movement, other days it probably records about 1 in 10 movements. I'm thinking it's a useless product but hoping someone can give me a fix that will actually work.
Have you tried using the motion detection test? That should give you a good idea of how well the camera is detecting motion (independent of any network stuff), and also help you find the best sensitivity. https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
I am wondering - do you have activity zones enabled?
And to be clear the camera is listed as activated in Settings, Subscription, Manage Cameras?
Yes of course. I'm going to try letting my subscription lapse, perform a full reset then buy a new subscription. If that doesn't work then I think i'll take to Twitter to request a refund!!
i got the same problem did all the things suggested by support just like you did but still dont record at night and now they dont even reply to my e/mail but if i stop my subscription i will have 3 camera and doorbell doing nothing and up to now its cost me £1,100+
tried removing and re syncing all but no better in fact 1 has stopped recording at all
wallum,
If you manually record with the camera during a live stream, does it produce a library recording?
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
