Arlo app stuck on logo. iOS 16.2 Tried rebooting uninstall reinstall offload app reset network settings. The thing does not load at all
i spent over 1000 bucks on all the arlo devices. What kinda crap is this?
Just wow! thank you thank you thank you. You are awesome! I followed a subset of your steps and that fixed it. Here are my steps:
1- Turn off Arlo iCloud storage ( under iCloud under your apple ID->Settings->apps using iCloud-->turn off ARLO)
2- Turn on airplane mode and kill ARLO app by sliding up.
3 - I started Arlo App - then it asked to log in
4- re- Enabled LTE /. WIFI
5- Entered my credentials for Arlo
Thanks again. I wish ARLO would have helped us out after spending $1000 on their equipment.
HI @Nik76
Are you still experiencing this issue with your Arlo app?
Yes, I am still experiencing it. I have tried every single solution offered on these forums and the internet. Can't get past the splash screen.
Thanks for the video, logging in via the web portal on a pc works fine correct?
Which model iPhone does this occur on?
Does it occur on any other handheld devices?
Does this occur on mobile data as well?
iPhone 14 PRO MAX and iPhone 14 Pro both.
Yes happens on LTE data as well
IOS 16.3
Works fine on the desktop/laptop browser.
Okay thanks, I'll provide this to my team and update you as soon as possible.
I am also having the same issue. Also stuck on welcome screen on my iPhone 11. I am running iOS 16.2. I have tried resetting everything except erasing the phone deleted the app and reinstalled it a bunch of times. I have a case open now, but no solutions yet! Everything is working correctly on the web interface. I of course tried LTE and WiFi several locations.. nothing is working
I am new to Arlo but very disappointed, this is unacceptable for a service used for security
Tamim
I know you are in the same boat as me somebody reached out to me and they open the case for me too but there is zero resolution.
I also agreed that for a product this expensive and used for security. This is truly unacceptable.
Thanks for letting me know as well. I have reported this and I will provide an update ASAP.
Nick,
I fixed my problem.. no help from Arlo support of course!
So I think what is happening is something corrupted in iCloud data related to Arlo app. So here is what I did, my iCloud storage was at 100% full which I normally ignore since I don't care about that. Arlo app does write some data to your iCloud account.
1- I turned off Arlo iCloud storage ( under iCloud under your apple ID)
2- I removed my phone from Arlo trusted devices, you can do this from Arlo's web interface
3- I also changed my Arlo password
4- after all this, I turned off LTE and WiFi on my device - I believe this is the most important step because it forced the phone not to go and fetch anything from iCloud.
5 - I started Arlo App - then it asked to log in
6- re- Enabled LTE /. WIFI
7- Entered my credentials for Arlo
now it's working !!! woohoo
I hope this works for you as well
Cheers
Tamim
You are welcomed, I am happy it fixed the issue.
I agree Arlo tech support is not where I expect it to be for the equipment cost and subscription fees that we pay.
Is anyone still experiencing this issue?
YEs - I am and the above didn't fix mine. 😞 So frustrating.
If they tell me to uninstall and reinstall ONE MORE TIME lol.
I had same issue.
To get it to work I followed the same steps but also turned off wifi when placing on airplane mode in step #2.
Arlo support was useless
Cannot work out why Arlo app is stuck on the attached screen. Have tried reinstalling, turning phone off, nothing works
The app will not launch on my iPhone 13 when I launch the app I get the blue location arrow then it goes out. I can launch the app on my iPad.
HI all,
trying to open the arlo in iphone 12, however the screen is freeze and it shows logo only, even there is no place for entering username/password
...tried to delete the app and reinstall, tried to restart the iphone ... it does not solve the problem.
...tried to clear the cache or offload app... it does not solve the problem.
We appreciate your help.
Bonjour,
Je ne parviens plus à ouvrir l'app ARLO secure sur mon Iphone8 (juste l'écran bleu avec la maison et c'est tout)
et ce depuis dimanche matin.
Cela fonctionne sur le téléphone samsung de mon épouse et sur l'Iphone10 pro de mon fils.
Je ne reçois pas non plus les notifications.
Aidez-moi s'il vous plaît.
Olivier
Try launching the app with the phone in airplane mode, and see if you get the login button then.
I've been trying to login on my new Iphone 14 pro max, tried several times to no avail. it says unknown error.
I have tried uninstalling and re-installing the app on the phone.. that also did not help at all.
I still cannot login to my account.
Someone help???????
The Arlo app isn’t working. U open/launch and it just has the page with the logo, is not prompting me to log in and does not load anything. I have deleted 3x and retried with no success.
Do you still have access using the web site login?
Us but I’m using my phone so when i log in on sugaring or google and select to “view cameras” it tried to launch the app which isn’t working.
add TAX number
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
billing
cameras
custom modes
Friend
Grant Access
My Arlo
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
