Arlo app stuck on logo. iOS 16.2 Tried rebooting uninstall reinstall offload app reset network settings. The thing does not load at all
i spent over 1000 bucks on all the arlo devices. What kinda crap is this?
Expected behaviour using a mobile, need to use a pc web browser.
Doing this will confirm that your account is still working.
Have you tried repowering the mobile?
Yes I can get in online and see the camera history. App still isn’t working.
The Arlo Secure app on my iPhone isn't functioning. It opens, but is stuck on the full blue screen with the House Icon. I've deleted and redownloaded the app, but it remains stuck.
The app for my iPad works, but I have not been able to access the iPhone version for about a week.
I've tried reaching out to "Support" and a bot just tells me to download the app from the store. Is there an actual support system at Arlo, and if so, how does one contact them?
Something happened yesterday afternoon on the app all of a sudden decided not to work on my iPhone 14 iOS 16.4 (i was already in 16.4 before yesterday). The app does not want to get stuck on the launch screen. I’ve been able to access my account via the Web on my iPad and on my daughters iPhone 14, which is not on iOS 16.4. Fix your app please!!!
Same issue here. Arlo support has not been helpful this far. Are you on iOS 16.4?
I am, I updated yesterday hoping that would solve the issue but the result was the same.
I have been able to access the camera via the iOS Home app, but I can't access the Library and don't get alerts.
Putting it in airplane mode worked for me. It forced it to log me back in.
I found similar posts and managed to resolve this, like others, without support from Arlo.
I put my phone airplane mode and opened the app. It had been force closed by sliding it up.
Once I opened it, it showed the log in screen, and I turned off airplane mode to allow for the log in.
Can you provide a screenshot of the error message?
I’ve been trying to get a response from an Arlo rep for over 24 hours. When I launch the app i just get the blue launch screen with the house and no error. This is happening on iPhone 14 iOS 16.4. I’ve successfully been able to get the app to work in another iPhone 14 that isn’t in iOS 16.4 yet, an iPad and the website. Please update the app for iOS 16.4.
I tied this yesterday and it did not work but it just worked now. Thank you. Do you have to do this every time you launch the app?
won’t go past the logo screen.
tried to restart phone and also reinstall app to no success
It didnt show the error code. It only show " unknown error" on the screen
I havent updated the ios.. still on ios 16.2..
I will update it asap..
I have updated the IOS, uninstalled then reinstalled the app.. it still shows " unknown error"...
I don't think so - though I haven't run into this on my own iPhone, so I am not sure how often it is needed.
Can you provide a screenshot of the error messaging?
There is no error message, it just gets stuck on the blue launch screen with the house. I was able to override by putting my phone in airplane mode while launching the app and then it would prompt me to log in.
This is what i get when i try to login
I can not het the App on my Cell to go past blue screen… hub is ok blue lite on
Try restarting the phone, and put it into airplane mode. Then launch the app. You should then get an internet connection error.
Then put the phone back into the normal mode, and see if you can log in.
I was having this problem and I clicked on log out instead of log in. Then I clicked on log in and it went to the next screen to enter email and password. Hope this helps someone else having this issue.
When I try to open the arlo secure it app it just opens to the blue screen with the house and circle. The login boxes are missing. It doesn't progress. I updated my phone and the app. The app works on other devices.
I also deleted the app and reinstalled it. No go
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
