Wanted to call out that the iOS Arlo app needs fixed. Tried to log into the iPhone Arlo app and I have it sending the verification code to my email. When i switch to outlook on my phone to get the code and go back to Arlo. It basically goes back to the login screen and wants to send another code.
This process makes it so that I have to have a computer in front of me to read my email for the code.
I suspect that the behaviour is by design so you always need to have a second device to use 2nd factor identification.
If you have to do this every time to login with the phone you need to set the iPhone as a trusted device and you can also set it as your primary device if you want it to receive the push verification enable action.
On the arlo app go to settings/profile/two-step verification and edit to change the tick position.
I think normally folks wiil set the app to trust their phone, which works around the problem.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
