Zones Not Working
  • 1 Reply
  • 10548 Views
  • 4 Likes
nileod
I've set up a zone so that the Arlo Q doesn't go off all the time but it doesn't seem to be working. The zone doesn't even have the street in it but cars driving by set off the Arlo all the time. Does anyone have a suggestion of what I can do to fix this?
Once you create a zone you must use it in your modes.  Use the Mode tab, select your camera and edit any modes you use (Armed by default). Edit Motion Settings and select the zone you want to use.  Be sure to save as you back out.
