  • 7 Replies
  • 4344 Views
Q cam acting a bit off last night....Discovered the IR light on ( usu off as it's against the window right now , to stop reflection  as it washes out the view.)
Looks like a new SW update ( not sure if official release as sometimes a small group get a field release first  but usu an email alerts first )
New version is 1.8.0-5551
Also, Noticed the led flashing at about 1am when coming home... purple which means wifi low signal.
Checked out online and found the Q cam went from Full wifi signal to 1 bar which was causing the flashing... no change on the wifi system/range here , wondering if the sw changes ( which seems to be ) is the cause as rest is status quo.
Only other answer is the wifi unit on Q going. ( reset no change but notice I had toggle on the IR, then off and save both times as on tho settings said off )
It appears the new release for the SW ( 1.8.0-5551 ) may be a pre release as i can see the possiblity of a new version to support the new Q Plus
7 REPLIES 7
I replied in a PM but I've had issues recently with night vision turning on during recording, seemingly because of a bright light flashing onto the camera (headlights or brake lights).  I have an open trouble ticket on this.  However, it was with the previous firmware, 1.7.4_5517.  I've had other issues in the past with night vision turning on but not for a long time and the symptoms were different.  They used to be like you just reported - IR LEDs on even though selected to be off.  More recently, it was just during recording.  Unfortunately, due to the troubleshooting with support, I can't be sure what may have affected the issue since the camera has had the settings toggled, the camera has been restarted via software as well as power-cycled, a factory reset, etc.  I initially had an issue with the new firmware causing the schedule to not arm the cameras while selecting the modes worked fine but now that's all working fine.
As a PS... I wonder if the WIFI level was lowered in the SW re lowered signal to my router
Not that I can tell but...
This is one of those times when I really want the ability to revert back to a previous version of SW.
With the USB port, it should be easy to run a loader and various versions of SW to dump into the cameras
Still having issues? No problems here but have reset and twiddled night vision settings. With the reset I obviously had to regenerate my modes and schedule.
Still acting a bit off... IR lights now stable after a few resets and toggle/save routine.
Power level from Q still off and the only change was SW update.  Really want to put the old version on to see the changes
