  • 6 Replies
  • 1249 Views
alexlee1116
6 REPLIES 6
have you tested it via the web to see if the arlo system or phone app?
https://arlo.netgear.com
alexlee1116
The arlo q have a bright blue light it's connect with my WiFi but I can not see on mobile app or web.
It's install before but I delete it accidentally I want to connect it again and using a add new one method...its still not working
If you mean you deleted it from Settings, My Devices, just use the Add Device selection on the Devices tab to sync it normally.
BindiB
My Arlo Q blue solid light is on. However, I don't see it on my app or mobile phone.  How can I see the recordings?
alexlee1116
Yes    i following the add device method but it still not show on my apps
Try using a web browser instead.
