Arlo Q keeps disconnecting from WiFi
  • 1 Reply
  • 1006 Views
PhilJW
My Arlo Q keeps disconnecting and reconnecting to my Wifi about every 5 minutes.
This isnt normally an issue as when it reconnects it continues to function as Ive set it up.
However if I am recording, this then stops the recording. Is there any way to get it to automatically restart the recording when it reconnects?
no...
First thing to try is a full reset... hold in reset for about 10 sec till led flashes then resync
test
If still the same, for temp try and move location in case of interference there.
If still ng, contact support for possible warranty
