  • 6 Replies
  • 3127 Views
ds2017
I got a new Arlo Q today and set it up and it was working with no known problems. Then I went to Settings and saw a red letter note to "update firmware". I did that and it went offline!
Now it will not reconnect. I can get to the OCR and it chimes. Then about 20 seconds later I get the reject buzzer and a message to try again. I have a PC laptop computer and four older standard Arlo cameras are working.
ds2017
I just now called support on the phone. The tech person was excellent. My Arlo Q is working fine now. He had me reset the camera (which I had tried before). This time I waited 20 minutes to let firmware update. The "Update in Progress" pop-up box did not ever go away on it's own. Arlo does need to have a pop-up box that says "Update Complete".  Thanks, David Stephens
6 REPLIES 6
Streak2
Master Master
You may have to try and reset it. Press the reset button until the camera clicks and the LED flashes amber.
Then try and sync again.
ds2017
I tried the re-set on the Arlo Q. I heard it click after about 15 seconds and then it amber flashed again. I restarted router, computer and camera. Still getting the bad buzzer after the OCR chime.
Streak2
Master Master
Just make sure that the phone/computer you are using to set it up is on the same network that you're trying to connect the camera to.
Failing all of this I would look at having the camera replaced or contacting support.
Possible that something got screwed up during the update.
https://www.arlo.com/en-us/support/
ds2017
Later today I got the Pro 2 (VMB4000) and two Arlo Pro 2 cameras. The base station is working because I have one new Arlo Pro 2 camera working, plus two three-year old plain Arlo cameras working. I am still unable to get the brand new Arlo Q camera to work. I did have it working shortly until I tried to update the firm ware as required in the pop-up box on the initial camera image.  Maybe I accidently cut off the update. Both this laptop and the base and the Arlo Q are on the same network.
Also, on my devices I am showing two base stations but only one shows a red dot showing it's on. I did delete the old original base station that was three years old.
If that has happened , it may be bricked... contact Arlo support
ds2017
