  • 1 Reply
  • 3888 Views
cricenog
There are other posts on this and the solution is to uninstall and re-install, this does work but unfortunately not something that is feasible every 2-3 days.
What's happening is I will be at home and geofencing will set away, and often when I am away, geofencing will set home. Often when I re-open the app.
It eventually corrects itself.
Is there a fix for this in the works?
Thank you
cricenog,
The app always needs to be running for Geofencing to work. Are you logging out or force closing the app?
Also be sure you do not have any settings enabled on your mobile device that automatically close apps after a period of time (battery saving settings).
