  • 1 Reply
  • 3723 Views
LPletch
I set up my ARLO Q and seem pleased with it so far. I may want to try it in a number of locations, but I'm concerned about unplugging it and plugging it in again.  If Arlo is unplugged and plugged in a different spot (still in wifi range), will it reattach to the wifi on it's own?  What if it is disconnected for a few days or maybe a week? Any problems re-aquiring the wifi?
LPletch
If you unplug the Q cam, and move it, it will auto reconnect if in range....
After a few days, it should, but not 100% sure...
