I have a couple of ArloQ's. One has the CVR option and the other not. Following all this weeks updates to introduce Smart Notifications (UK) the ArloQ with CVR no longer saves motion detected video clips to the library. When I look at the CVR screen though I can see the green flag when motion occurred and can view what was captured at that time. The non-CVR camera saves vidoes as it always has.
BUT, no video clip is saved to the library from the ArloQ with CVR.
After various camera reboots, which made no difference, I decided to move the CVR subscription to the other camera. Now the first camera saves clips again, but the other camera with CVR stops!
So, it is quite clear that after using CVR with this camera for the last two years, this week has introduced a bug which has stopped it from saving to the library.
I have removed my CVR subscription altogether for now until Arlo confirms a fix.
Called support and spent over an hour "troubleshooting" before finally getting issue escalated to next level support. No, they do not monitor this community. This CVR issue that I raised today was, apparently, 'the first time we have heard about this problem". Now I wait with bated breath . . . . . . .
I managed to get my case escalated (or as tehy called it endorsed) to the next level of support and was told that they would reach out to me when the engineers have something to report back.
@cloudwizard it will be interesting to know their feedback, thanks.
Does anyone know of a solution?
I had similar issues a month ago when I was traveling. When I returned home it either fixed itself or wasn't working while away via my phone.
Hey everyone,
Our development team is currently looking into the problem where some users are experiencing event recordings are not being saved for CVR-enabled devices. We will provide an update as soon as we have more information to share with the community. We appreciate your patience and understanding.
@JessicaP thank you for the recognition of this issue. Looking forward to a quick resolution 🙂
That did the trick! Thanks very much for your responce. I appreciate it.
I did that and the camera worked for a couple of days. But now it's not wroking 😞
I too have stopped receiving notifications and recordings. Nothing on the camera has changed, but the services have changed. Recently, Arlo introduced new services like Vehicle and animal detection. I noticed that I stopped receiving notifications shortly after they introduced the above services. I have disabled the new services, but kept the people detection, since that was the original one when the camera worked. For now, the camera is sending notifications, but only time will till if this will continue to work. It's pretty sad when they don't thoroughly test their software, break paid services and take their time in getting around to fix it. I wonder if they even know that it’s broken. Well, best of luck.
Nothing is being added to the library and I am not being notified of activity.
Thoughts?
CVR gives a constant video recording to the cloud. You can access it by clicking the clock icon on the web interface or in the app click the 3 dots to the right of the video counter and then click Timeline.
Video clips will only go to the library if there's a rule in your mode that tells the camera to record, just as it would if you didn't have CVR enabled
I just created another mode for this camera alone and will see if it works.
The timeline also doesn't work.
I have 4 Arlo pros and 1 Arlo pro 2 with a CVR plan on it. When I first activated this plan for this camera it worked fine for couple of months, I was recieving motion notifications with recordings in the library as well as cvr function. Recently for past couple weeks I stopped getting notifications from this one camera. I talked to customer support and they couldn't seem to find a solution. Upon further troubleshooting on my own I noticed when I take that camera off the cvr plan and restart the system I get back the motion notifications and recording in the library. When I add that camera back to cvr im back with the same problem. It's either one or the other for now. Has anyone else had this issue?
Is that camera definitely assigned as the camera using CVR?
Hi @steve_t
Yes it is. I have 2 out of 3 with
CVR.
Library upload still works for the 3rd without CVR
No activity captured in the timelines where green line is showing either??
I did try yesterday and today i recived recordings. Thanks 😉
Best regards Steffen
Yes, I did. Yes that fixed the issue. So they introduced new features with out compelete testing. Oh well !! Thank you.
One more note, after you disable the new services if you enter an email on the Mode->Rule-Notifications on the CVR camera, you will get the email notifications for vehicles, animals and motion, but in the app you will only get the notifications for people. Actually, they should make rules like that. For example, record vehicles, but don't send a notificaiton to the app or record people and send notification to the app. Maybe some day they will get it right.
Thanks anyvay 😉
Have you tried to reboot the camera & monitor the issue?
Arlo Q
