  • 3896 Views
Djleeson
Would like to have additional cameras but some wireless ones too outside. Can I buy any kit bundle and they’ll all work together in one app?
The Arlo cameras will work in the same app/web access prgm.... BUT they can not be armed ( arlo & Q ) at the same time.
They are really 2 separate systems that appear in the same prgm, each will require/have it's own arming, schedule, etc
Djleeson
Thank you. Tbh., I just use the fixed camera as a baby monitor but it sounds like it might be easier to just put wireless ones inside and outside and keep the “baby monitor” one as it is.
I find it to my avantage with multi camera systems... It allows multi schedules and arming without effecting others
( YMMV )
