  • 1 Reply
  • 3630 Views
onlydave7
Why does the microphone keep turning on when it is turned off in settings and saved?  I have allowed one guest but did not give them privileges.
Thanks for the heip.
Only thing I can say is
1) make sure you are saving on the exit from the settings ( sometimes the save is on the 'back - out ' page )
2) make a new friend account for yourself ( new email ) and give you the same options as your current user and test how much control you have.
