AC Adapter Making Noise
  • 2 Replies
  • 2156 Views
matt_lisiecki
The ac adapter to all three of my Arlo Q’s makes a high pitched “clicking” noise when plugged in. Has anyone else experienced this and do you have any suggestions to stop the noise?
Have you tried another type USB adapter?... Is it actually the adapter?
The Q will run from a normal 5v USB at around 1.5+a rating.
matt_lisiecki
I have three AC adapters from Netgear and they all make that noise.  I bought a replacement off Amazon that does not make the noise.  Seems to me it is something Netgear/Arlo should look into redesigning. I won't be buying another product from Arlo.
