  • 4 Replies
  • 3242 Views
Grif11
 I have 1 Arlo Q Plus camera. What is the best product to add a wireless camera outside? I have it set up as wireles- the ethernet connection did not work.
In order to use the Q+ camera and ethernet, does your router support or did you turn on  the POE so the camera gets power?
Grif11
Im just going to get an Arlo Plus with base and hook it up separately. I just have my Arlo Q plugged in operating wirelessly. It seems to work fine. I was worried about my wireless connection, but it is operating  fairly well. Any tips on setting up a Arlo Plus and Arlo Q to integrate at all?
Arlo Plus?  Do you mean the Q Plus (similar to the Q with PoE capability) or the Pro or Pro2? Either way, they will be seen as separate systems which will appear in your app/browser as separate entities.
Grif11
Yes I have the Q Plus and Arlo Pro. Ill be setting up ater today- wish me luck!
  • 4 Replies
  • 3243 Views
