Arlo Q Plus on 3 mbps upload and 1 mbps download
  • 1 Reply
  • 1394 Views
johnwiater
My seasonal internet speed (when away) is 3 mbps upload and 1 mbps download.  Just wanted to validate these speeds will be sufficient to run, capture and view live when I'm traveling?
The important issue is your upload speed.... the Q camera can max at about 1.4Mbs at times tho mostly a bit lower.
( or if needed you can lower the rez a bit to 720 )
If your upload speed is as mentioned, you should be ok.
  • 1 Reply
  • 1395 Views
