I am concidering the Arlo Q Plus camers for a small security set up. What is the maximum distance that a PoE cable can be between the camera adapter and the router?
			Switches For Surveillance
CalWilson,
802.3af and 802.3at PoE standards have a distance limit of 100 meters or 328ft which is also the limit for the data transmission for Ethernet cables.
