  • 2 Replies
  • 3790 Views
Lilly007
I just want to plug power and start recording, nothing fancy, no oline, no ethernet
Can it be done?
I have spent 3 hours trying to get someone to answer this question and there is no support number
Does anyone have support num ber for US?
Just got it and may return tonight
So frustrating
Lilly007,
You need to have the Arlo Q Plus connected to the internet to initiate the New System Setup process and start recording. You can refer to your Quick Start Guide to get started, or take a look at the digital guide here: Quick Start Guide
If you would like further assistance by contacting support, see here: Arlo Support Team
I don't have a Q+ but it would seem that once the system is up and working you could cause the router to not provide an IP address to the Q+ by blocking the MAC address or by setting up using a guest network and then turning it off. How useful this would be is unknown but seems like it should work.
  • 2 Replies
  • 3791 Views
