what base stations works with older arlo pro cameras and 5g
They all work with the Arlo Pro and the Pro 2. Older bases (VMB3xxx models) won't work with Pro 3, Pro 4, Essential, or Ultra. Details for each base/smarthub are here:
@eileenfst wrote:
what base stations works with ... 5g
Not sure what you mean here.
- All base stations/smarthubs connect to the internet using ethernet (not wifi).
- Most Arlo cameras only have 2.4 ghz wifi. The only dual-band models that use a base station/smarthub are the Ultra / Ultra 2. The only dual-band smarthub is the VMB5000.
I use the VMB5000 and have some Ultras. IMO, the ability to connect at 5 ghz isn't that important when you are using a base - 2.4 ghz has better range, and most of my cameras are far enough away from the base to get a better signal using 2.4.
