sense movement from one area to the next>
  • 3113 Views
  • 3 Likes
Jetman350
Just set up 4 camera's around my house. Last night my driveway camera picked up the paper boy driving in to drop the paper on my front porch, BUT the front porch camera did not show him at all. Is this because the drive way camera was still recording? If so I guess my option is to shorten the recording time so the porch an pick it up?
Wklovelace3
Virtuoso
Virtuoso
No they work seperate. It should have recorded. My two work together. You can even set up a custom mode that when one camera records it triggers another camera. As to why it didnt pick him up it works better from side to side not head on. The infra red spread out as they leave the camera so try different angles
You can also create a custom mode with rules that will detect on one camera but record on another:
Cam1 detects, cam1 records
Cam1 detects, cam2 records
Cam2 detects, cam2 records
Cam2 detects, cam1 records
Jetman350
Thanks for the tips. My front door camera is at an angle of about 45 degrees, so the head on isn't the problem. I'll do a little more testing and see what happens. Of all the videos I have watched and the community is still the best for info.   Thanks.........
