  • 17 Replies
  • 3778 Views
kmascotto
17 REPLIES 17
kmascotto
also the time line is screwed up...file length listed as 7 sec total
Is it the same downloaded to local computer?
kmascotto
Yes the file is the same once downloaded
kmascotto
The download was 21 seconds long...but still looked the same
There appears to be some corruption in the stream.  I see something different when I play it with avidemux (instead of VLC).
Also, with avidemux, I see something odd when I go frame by frame at 6.982 seconds..
https://sourceforge.net/projects/avidemux/
kmascotto
what do I have to do to fix the issue?
ShayneS
Have you  tried to reboot the camera or remove it from Settings > My Devices > Re- Add it?
kmascotto
How do I reboot the camera?
kmascotto
ShayneS
How often do you experience this lag in your videos?
kmascotto
It’s happened many times. But only on that camera. The other 3 work fine.
ShayneS
To reboot the camera you can open the battery door and remove > re-insert the battery. If this does not help, you can remove the camera from Settings > My Devices > Re-Add it.
kmascotto
I will try to get that done when I get home today. I’ll let you know if anything changes
kmascotto
So I rebooted the camera and disconnected and reconnected the camera... here are the results.
https://my.arlo.com/hmsweb/users/library/share/link/26E5E444370D18EF_201910
ShayneS
Thank you for providing the video. I would like to suggest contacting customer support regarding the individual camera. I would also suggest mentioning this thread & the steps we have taken so you can let them know what has been completed. I have provided the link for you below.
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
kmascotto
I contacted support last week and received a note saying they would get back to me in 1 to 2 days...still nothing
ShayneS
Hi @kmascotto
I have escalated your case for you & customer support will be reaching out to you as soon as possible.
