https://my.arlo.com/hmsweb/users/library/share/link/7E1F3DEC908D0772_201910
The Camera has done this several time...
also the time line is screwed up...file length listed as 7 sec total
Is it the same downloaded to local computer?
There appears to be some corruption in the stream. I see something different when I play it with avidemux (instead of VLC).
Also, with avidemux, I see something odd when I go frame by frame at 6.982 seconds..
Have you tried to reboot the camera or remove it from Settings > My Devices > Re- Add it?
This was this morning....at the 7 second mark.
How often do you experience this lag in your videos?
To reboot the camera you can open the battery door and remove > re-insert the battery. If this does not help, you can remove the camera from Settings > My Devices > Re-Add it.
https://my.arlo.com/hmsweb/users/library/share/link/26E5E444370D18EF_201910
Thank you for providing the video. I would like to suggest contacting customer support regarding the individual camera. I would also suggest mentioning this thread & the steps we have taken so you can let them know what has been completed. I have provided the link for you below.
Hi @kmascotto
I have escalated your case for you & customer support will be reaching out to you as soon as possible.
