my Arlo camera shows yellow when I view it.
  • 5 Replies
  • 3892 Views
Rue_Doo
hey Arlo Fam. My camera shows yellow when I view it. Is there any way I can fix that?
5 REPLIES 5
steve_t
Master Master
Remove the battery for 10s and replace. When the camera resyncs itself to the base, check the video feed again. If it's better, great. If it's still the same, contact Support at the bottom of the page, most likely for an RMA
Rue_Doo,
Are you referring to the image on the stream or an LED behavior? Did the suggestion above solve the issue?
Rue_Doo
Hi James,
The Yellow is a stream issue when my light comes on it shows Yellow I have been closing the app and re opening it. Sometimes it works and some times it stays Yellow
Rue_Doo,
Can you post a screenshot or a video of the behavior you're seeing? This might help us better understand the issue.
Rue_Doo
Hi JamesC,
If it happens again I will send a screenshot of it to you.
-RueDoo
