Not sure what you are asking, but if you mean that will the original cameras work with the Pro hub the answer is yes. And the Pro cameras will also work with the original base.
Brian
any of the arlo bases will work any of the cameras ( that use a base )
how do I test my VMB 3000 hub I think it is faulty
thevistas,
What issue are you experiencing that indicates the base is faulty?
