cannot get new out of the box Pro 4 cameras and base to sync
Tried every which way I can but cannot for the life of me get the new out of the box arlo pros and base to sync
no Im not a tech geek but I get technology
thanks
A couple of possibilities.
- Make sure you're only pressing the base sync button briefly - don't hold it.
- Weak/bad batteries. Try plugging the cameras in using wall power and try to sync. If that works, it may be bad batteries.
- Bad cameras. Not much you can do about that other than to swap at the store or open a case with support.
