my Arlo pro system has been offline all day. I have rebooted router, unplugged arlo base station, and even reset everything numerous times
the base station connects and all lights are green. when I check status from app or even arlo arlo website I keep getting system disconnected messages.
I would very much like to get this thing working.
We are currently investigating this issue. I will post an update as soon as I have more information.
JamesC,
Thank you. Is this also the reason I have no access to change my motion sensitivity and email notificaiton settings?
Autumn
I'm having the same problem. Any answers yet.
I bought this arlo pro about 6 months ago. every thing work fine until today. the base station is offline. i try push on/off button. disconnect the power. and hit reset button. but nothing work. finally i decise to remove the devide and try to re install it. but the base station can not discovering. and show the solid 2 green light on the left and a solid orange light on the right. nothing wrong with the internet because i can watch movie from same internet provide. i don't know about the firmware right now. because i cannot log in to my base station any more.
Having the same issue here too. It started today, the base is "OFFLINE" but it still records video and sends alerts. I can't see anything in the live view and I can't open the settings for the base in either the phone app or the website.
I hope they didn't brick these things.. Mine's been pretty flawless unlike all the other folks having issues. This would be the first real problem I've had.
Same issue as everyone else today, check power & internet connection. Has worked great for over 2 years and then today this. Please resolve issue, clearly on your end.
I have VMS4430-100NAS and an Arlo Q. While at work, one of my cameras was offline. I tried resetting the system from my phone at work, and it took all of them offline. Upon getting home, I tried doing a factory reset holding the reset down 10 seconds. Amber blinking lights then switched to Green Power and Internet connection. I go to Add Device, and the base station won't sync/connect. Tried for 2 hours now and now phone number to call. Have taken all batteries out of cameras and unplugged the Q. Have powered off modem, router, Base station and powered back on in order to no avail. Help please
how do i fix this problem
It seems to back online all of a sudden and working like it should. Do you know what happened to fix it?
The Arlo engineering team has identified the cause and resolved this issue. Please let us know if you continue experiencing this behavior.
Basicly, I have to drive back over to the house to reboot the system to get it to work?
I am not in love with Arlo at this moment...
For some reason my system is back up and running now. They might have fixed something on their end. Try logging back in, yours might be fixed already as well.
Hoping this will resolve with time or I will be calling this afternoon....
No dice JamesC / Arlo. It still says the base station is disconnected.
