bought and successfully installed arlo pro on arlo wire-less base which connects to my 2 other arlo wireless camera.
with arlo app on my iphone, audio from arlo pro was working fine until suddenly no sound is coming out.
tried restarted but problem remains.
resync works!...tks
Try popping the battery out to reset the camera.
Audio out of the camera has been an issue using mobile devices since we have no control over the mic gain on these devices. Use of a computer allows mic gain control which works well. Have you tried a browser on a computer to verify the issue?
If able, test the system via a web browser on another device ( to eliminate the phone issue ) ,, go to https://arlo.netgear.com/
If it works on the web , then the problem is the phone.
If NG on the web, I would check the settings to make sure the mic/speaker is toggled on still, and-or power button reboot the base
tks, i tried removing / re-inserting battery, problem remains.
also tried accessing from browser, audio is also not coming out.
i also tried restarting the base, there is still no audio.
there is very weak hissing sound, but definitely not the sound produce from the other side
Sounds like a hardware problem. One last step - remove the camera from Settings, My Devices and resync it. If still nothing, you may be able to swap at the store or open a case with support using the Contact Support link at the bottom here.
I am having the same issu. Talked to the support. They are aware of this issue for iPhone. No ETA for the fix yet.
resync works!...tks
does Argo pro have audio
Yes.
